Perform this procedure to configure remote Shortest Path Bridging MAC (SPBM) on an interface.
- Select IS-IS Remote.
- Select the Interfaces tab.
- Select the SPBM button.
- Select Insert
- Configure the interfaces SPBM parameters.
- Select Insert.
SPBM Field Descriptions
Use data in the following table to use the Interfaces SPBM tab.
Name |
Description |
Index |
Specifies an Index value for the remote SPBM interface. |
SpbmId |
Specifies the remote SPBM ID. |
State |
Specifies whether the remote SPBM interface is enabled or disabled. |
Type |
Configures the remote SPBM instance interface-type on the IS-IS interface on the specific port or MLT, the values are point-to-point (ptpt) or broadcast (bcast). The system supports the ptpt interface type only. |
L1Metric |
Configures the remote SPBM instance l1-metric on the IS-IS interface on the specific port or MLT. The default value is 10. |
Origin |
Specifies the source of the remote SPBM instance configuration.
